-   -   Broken trip lever in tub (http://www.diychatroom.com/f7/broken-trip-lever-tub-16239/)
cibula11 01-27-2008 06:47 PM
The trip lever on my tub's drain snapped off. I don't think it even worked to begin with. I am thinking that I will just unscrew the two screws and buy a replacement cover with the guts. Are these difficult to replace? or should I be consulting a plumber?
Mike Swearingen 01-27-2008 07:19 PM
Easy fix.
Just unscrew the two bolts and lift, wiggle and pull out the assembly.
If the assembly looks good and you can clean and lube it, just replace the trip lever, cover and bolts, and attach the old stopper assembly with a cotter pin to it.
Good Luck!
Mike
jte1130 01-28-2008 01:54 PM
I just got some advice on replacing the trip lever a few weeks ago on the forum. Its definitely an easy fix as Mike said. I think it cost me about $6 for the new trip lever.
