The trip lever on my tub's drain snapped off. I don't think it even worked to begin with. I am thinking that I will just unscrew the two screws and buy a replacement cover with the guts. Are these difficult to replace? or should I be consulting a plumber?
Easy fix.
Just unscrew the two bolts and lift, wiggle and pull out the assembly.
If the assembly looks good and you can clean and lube it, just replace the trip lever, cover and bolts, and attach the old stopper assembly with a cotter pin to it.
Good Luck!
Mike
I just got some advice on replacing the trip lever a few weeks ago on the forum. Its definitely an easy fix as Mike said. I think it cost me about $6 for the new trip lever.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
