Broken Trap-outside - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2009, 02:47 AM   #1
Broken Trap-outside
when using the washer in basement the water would start backing up. goes into set tub [that drain is ok] plumber came out and said street trap was broken and he'd have to dig lawn up to correct.. can someone explain what he meant and how this affected flow. everything else drains ok-it's just when you dump alot of water,ie-washer..Thank's, Harry.
Jacques is offline   Reply With Quote
Old 12-24-2009, 08:13 AM   #2
Rewards Points: 150
Set tub?.Does the rest of your house drains exit below your basement floor?If so and everything else is draining properly I say the problem is at the washer drain.In my experience,the street tap is where your house drain connects to the city sewer and if this was the problem than the everything would back up.Repairing the tap can be messy and expensive!
rudolph58 is offline   Reply With Quote
Old 12-24-2009, 08:19 AM   #3
Rewards Points: 150
I am sorry,I miss read your post.Street trap?I have heard of a house sewer main trap(A running trap to keep the sewer smell from coming back into untrapped basement floor drains).
Old 12-24-2009, 10:55 AM   #4
I would need to know how he came to this decision. Did he run a snake with a camera through the line? If other drains are running okay, this does not make sense. Years ago House traps were installed. This amounted to double trapping which is now illegal. I think I would get another opinion.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-27-2009, 05:35 AM   #5
to clairify; there is an old toilet drain in basement that is capped off. the pipe from this goes down and connects to main house sewer line. water started coming up through there when washer drained. plumber came out and put rod[?] down vent[?] outside, he said he pulled up mud which meant the trap[?]-terra cotta was broken and he would need to dig up lawn to replace. is this true??.. Thank's
Old 12-27-2009, 08:06 AM   #6
Rewards Points: 1,538
Even straight (no trap) terra cotta or even cast iron lines can collapse giving the symptoms you describe. Digging up and replacing is the only solution.
Old 12-27-2009, 08:48 AM   #7
Rewards Points: 150
You left that out in your first post!Happy digging.
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 12:40 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
