I installed hardwood flooring over the weekend and all went well until i was putting the toilet back on. the flange that bolts to the toilet snapped. a piece broke off right where one of the bolts mounts. I'm wondering if anyone knows a way to fix it without having to cut the pvc piping, running new, then installing a new flange.
there is a fix. go to your nearest plumbing supply, not ho depot. there is a metal repair ring for this . it looks like half a flange ,you slide it under the broken flange i forgot the name of it. dont forget your wax ring and new bolts
HD and Lowes both carry repair flanges. The ones I have seen are metal and you screw through the original 4 flange holes to secure it to the floor. One brand name is Super Flange.
the flange sits above the sub floor and is relatively flush to the hardwood. i found a repair flange last night at Lowes, but it doesn't look like it fits.
This is what I do, clean off the old wax real good, get a flange extender seen in pic below, use plenty of silicone between the old and the new flange and using 3" non corrosive screws secure the two together though to the wood sub-floor now you have new slots for the closet bolts to attach to. Use plenty of screws around the flange for a good secure fit.
Thanks for the help everyone. I ended up using the flange cover suggested by majakdragon. It fit nicely. I'll be putting the toilet on tonight or tomorrow. thanks again.
If you are speaking about the type with a plastic "horn" installed, I use them all the time. My thinking is that it "directs" the flow to the drainpipe. Some will disagree and I have heard they are not code in all areas. I use Kno-leak or Cant-leak wax seals. I have seen some that really reduce the size of the discharge hole though. One I saw went down to about 1-1/2". I would not use it.
Yes. As long as the wax seal is installed properly it will seal and thats the main purpose. I have installed many of the standard seals and never had one leak.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
