Broken Toilet Bolts - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2012, 07:52 PM   #1
Rewards Points: 135
Broken toilet bolts
I have a toilet that can be moved easily side to side at least two inches. I assume the bolts are broken probably rusted. There is just one toilet in the house. Before I attempt this repair what can I expect to find once I move the toilet? Could this be beyond my ability as a diyer? I have a new wax seal and repair kit for the sewer flange(?).The house was built in the 60's but I think someone worked on this toilet about 4 years ago.
elmaur is offline   Reply With Quote
Old 10-16-2012, 07:58 PM   #2
it should not be beyond your capabilities, Just remember to move slowly, and to not overtighten the bolts when you put the stool back on. If the bolts are broken, you may need a small screwdriver and needle nose pliers to get all the parts back out of the flange. Good luck.
merle is offline   Reply With Quote
Old 10-16-2012, 08:06 PM   #3
Rewards Points: 135
Thanks merle, so I will carefully remove the toilet, asses the situation and feel confident that I won't have to leave the occupant without a toilet till a plumber can get there.
Old 10-16-2012, 08:17 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
Be prepared to rebuild the flange.....
It's probably cast iron and broken.
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (10-16-2012)
Old 10-16-2012, 10:22 PM   #5
you just can't prepare for every contingencies so before starting, I would:
1. Contact few local plumbing supply stores and pick one with a well stocked store with most friendly counter person;
2. Start the project early so you will have enough time to go out and get necessary parts to finish your project before the plumbing store closes;
3. *NOT* reply on large box retailers to stock your part(s).
Good luck
allthumbsdiy is offline   Reply With Quote
Old 10-17-2012, 10:21 AM   #6
Rewards Points: 254
The bolts probably cracked the flange. You will need to replace the flange or get a flange repair kit.
pwgsx is offline   Reply With Quote
Old 10-17-2012, 01:05 PM   #7
Rewards Points: 610
may have floor damage as well.. e.g. wood rot due to leak around toilet flange ...be prepared...might have to do temporary repair then return and have to tear out part of the floor to renew it..hopefully not.!! Good luck!!
techpappy is offline   Reply With Quote
Old 10-17-2012, 10:31 PM   #8
Rewards Points: 135
The repair is on hold till sometime next week. The person using it is cautioned to sit gently... I should find some videos to familiarize myself what I might find when I move the toilet.
Old 10-17-2012, 11:29 PM   #9
Plumber
Rewards Points: 452
You'll also find a lot of threads here addressing similar problems. Try the search function too
Old 10-18-2012, 06:37 AM   #10
raylo32's Avatar
Rewards Points: 1,240
Yes, this. Just happened at my parents' house. They had a pro come in and fix the floor, flange, and plumbing. I got to repair the drywall ceiling below where the plumbers opened up a working hole.
Live long and prosper.
raylo32 is offline   Reply With Quote
Challenge: Toilet Leaks through bolts but only when flushed! racerted Plumbing 53 10-21-2012 10:06 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet tank bolts wilard428 Plumbing 4 11-25-2010 08:53 PM
Toilet tank bolts? FrankL Plumbing 7 09-05-2010 10:32 AM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
