Broken Spout On Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2009, 09:53 PM   #1
Broken spout on bathtub
Today I tried replacing fixtures on bathtub. I purchased a universal spout and the guy at the store told me turn the old one to get it off. Well turning it actually broke it. Now all I have is a piece of cooper bareley sticking out of the wall. How do I fix and replace this?
jmilesrcr is offline   Reply With Quote
Old 04-17-2009, 05:11 AM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Copper? Usually it is a galvanized nipple. Can you post a picture so we can see what you have?
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-17-2009, 05:54 AM   #3
Tub spouts can be secured in a number of ways. They can be screwed on to a fitting on the end of the pipe, there can be set screws at the front or rear underside of the spout. They can simply slide on with tight o-ring seals, etc., etc. As suggested, a pic can help us figure what you have and how to fix it. It does sound like you had the one with set screws. But now the copper pipe has to be repaired. It is either soldered into a fitting behind the wall or screws into that fitting. Is there access to the plumbing behind the tub??
Old 04-17-2009, 09:33 PM   #4
I will upload a pic.. but the pipe is cooper, the house was built in 1982. There is no access to wall behind tub unless I cut hole in wall.
Old 04-18-2009, 06:42 AM   #5
brokenknee's Avatar
That is what you may have to do.
Old 04-18-2009, 10:18 AM   #6
Wethead's Avatar
Hi,
All you need to do is just extend the "copper"
YES PEOPLE:
Copper used to be king before all the pex, gal etc.
Anyhow:
Go get a 1/2 copper coupling and some solder and a torch.
Then just sweat on a coupling and a new peice of copper.
Most tub spouts require a 5" nipple regardless if it's pex. copper, gal.
After you sweat on the extension, measure from the inside of the tub spout to the edge that touches the wall and then cut your pipe the same size and then tighten the Allen key.
Hope that helps!!!
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Tub Spout Help showerhelp Plumbing 9 11-13-2008 07:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Bathtub tub spout Diverter broken? tripower Plumbing 5 06-24-2007 06:44 PM
