Old 12-01-2012, 02:23 PM   #1
broken snake tip
My washing machine drain was clogged. I rented a snake and snaked it. The tip of the snake broke. It is draining now. Is it BAD to leave the tip in there or do I need to call someone to get it out.
zvegge is offline   Reply With Quote
Old 12-01-2012, 02:40 PM   #2
call me E
TheEplumber's Avatar
broken snake tip
The choice is yours- if retrievable you should remove it. At some point it may give you some issues, then again maybe not. I've seen broken cables left in main lines for extended periods. Eventually they have to come out though
The Following User Says Thank You to TheEplumber For This Useful Post:
zvegge (12-01-2012)
Old 12-01-2012, 03:03 PM   #3
broken snake tip
it was about a 2 inch tip and maybe a couple inches of line, the tip was probably as wide as a dime.
Old 12-01-2012, 05:21 PM   #4
Rav
broken snake tip
I don't know how far down it is, or how straight the drain is, but perhaps something like this might help get it out?
www.amazon.com/TEKTON-7597-36-Inch-Claw-Pick-Up/dp/B000NPR3WU
Rav is offline   Reply With Quote
Old 12-01-2012, 07:26 PM   #5
broken snake tip
well we snapped of a 10' section with a 2" cutter head 10yrs ago....still no problem..knock on wood ben sr
Old 12-02-2012, 07:53 AM   #6
broken snake tip
You never know with these things and it depends on the location and the position of the piece.
Sometimes people get away with it forever and sometimes it cause nothing but problems if paper and waste start collecting on it and it builds up and eventuality clogs.
Good Luck.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
ben's plumbing (12-02-2012), Javiles (12-02-2012)
broken snake in shower drain Wa! Plumbing 2 11-17-2011 07:40 AM
Snake Identification Giles Off Topic 1 06-05-2010 03:37 PM
broken drum snake cable, how to fix? confusedDIY Plumbing 1 03-18-2010 09:38 AM
Stuck Snake frederick70 Plumbing 22 05-13-2009 06:01 PM
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 05:45 PM
