Old 02-20-2012, 10:33 PM   #16
Broken shower head extension (soldered joint) - please help!
A question about this fix - is there any way to check whether my connections are leaking once the shower is installed? It seems like I'm going to have to just tighten everything up and hope for the best as I won't be able to see anything once the showerhead is back in place.
Simon96Taco is offline   Reply With Quote
Old 02-20-2012, 11:27 PM   #17
call me E
TheEplumber's Avatar
Originally Posted by Simon96Taco View Post
I did try to find brass, but the HD store brass nipple selection were either too short or too long...so the sales guy advised me to use the galvanized piece.
That's fine if you want to have rusty water on your head. Yes, it will happen with galv. pipe. I like Ben's advice, get a loner arm
Old 02-21-2012, 12:11 AM   #18
call me E
You can pull the trim plate back while showering and take a peak at it. Otherwise, no
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-21-2012)
Old 02-21-2012, 08:04 AM   #19
Originally Posted by hammerlane View Post
Then I would forget about soldering all back in there and buy a brass coupling(5) and a brass nipple(4) if you have the depth and put it all back like that
A reminder inspired by your specific pictures. The OP and anyone eavesdropping needs to make sure that the pipe threads match.
Never force fit non-matching threads even if you use plenty of pipe dope or Teflon tape.
It is okay to make up the entire shower arm assembly first and then screw it into the elbow inside the wall using the angled down portion of the arm assembly to crank it into place, no socket wrench needed.
Regarding leak testing:
If there is any play around the arm pipe where it exits the wall, you could turn it on for several minutes and shut off the water flow using a sprayer attachment on the shower arm, then peek inside with a flashlight to check for drips while it is under pressure this way.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 02-21-2012, 06:41 PM   #20
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What size nipple would you need for the shower head arm to sit flush against the shower wall when tight?
Maybe a friend that is good with soldering copper could make you a male to female adapter the right length.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-28-2012, 09:15 PM   #21
Apologies in advance for bumping an old thread, but was ashamed that I hadn't thanked everyone for their help and responses - problem solved!
Old 07-03-2012, 02:25 PM   #22
to threadjack. is it a given that the drop ear #1 in the picture will be there? Plubming is from the 20's. for whatever reason the shower arm is twisted about 20 degrees and its annoying. Before I wrench on it, I want to make sure I am not going to snap off some ancient voodoo connection.
jgold47 is offline   Reply With Quote
Old 07-03-2012, 02:48 PM   #23
Super Moderator
J gold--start a new thread--few will want to wade through 21 ancient posts to figure out what you are talking about.
As to twisting an 80 year old pipe?
I would not do that--that piping is long past the end of its useful life--
Do it when you repipe the house--or do it now and force your self to repipe the house now, Your choice.
Old 07-03-2012, 02:52 PM   #24
yeah - good point. Will make a new thread.
Well its been twisted and I would like to get it straight. I had good luck removing the hot/cold supplies to fix a leak, they looked like brass. Who knows if that stuff has been updated or not. I have been pestering the wife to let me rip into the wall to replace the (I am sure) galv piping and install a thermostatic set for the shower, but she's afraid of tiling and being without our only shower. going from the other side is out due to a fancy closet behind.
Old 07-03-2012, 03:05 PM   #25
Super Moderator
It's risky---and rebuilding an antique bathroom takes about two weeks for a pro with an assistant--
I would not want to be the one doing it in case a leak is the result.
Tags
help shower broken solder
replacing ceiling mount shower head JoanneW Plumbing 3 05-31-2010 09:19 PM
Shower head replacement zachg Plumbing 10 01-24-2010 09:21 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 10:05 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 10:19 PM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 07:30 AM
