-   -   Broken shower head extension (soldered joint) - please help! (http://www.diychatroom.com/f7/broken-shower-head-extension-soldered-joint-please-help-134336/)
Simon96Taco 02-20-2012 01:27 AM
3 Attachment(s)
Well, shamefully my first post here is a plea for help. I searched for a solution but all I came up with was solutions to the problem of the shower head stem itself breaking off inside the copper nipple. That is not quite my problem (please see attached pictures).
In my case, there is actually a short (about 2.5" long) copper extension coming off the main copper water line. piece has broken free at the soldered joint. This happened when I was trying to remove the shower head from the stem to install a new shower head.
My question is this - is there any way to fix this without soldering? I don't imagine it is possible to solder behind the wall, and fear that I now have to rip my shower wall apart to fix the problem I've created :(
Any and all help would be hugely appreciated!!
Simon
jammin06 02-20-2012 02:46 AM
Are you sure that fitting won't just screw out?
It looks like there are six flats around a male fitting that is screwed into the brass elbow that has the two screws in it.
Looks like that piece that came out was not soldered in correctly. Looks like it was not inserted far enough.
Try a socket on that piece in the wall. Can you see the flats? I'll bet it just screws out.
Good luck
plummen 02-20-2012 06:40 AM
Time to learn to sweat copper :)
hammerlane 02-20-2012 08:20 AM
2 Attachment(s)
Jammin may be correct. In your first picture if that drop ear elbow has a male adaptor threaded into it you should be able to unthread the male adaptor.
Can you provide a clearer picture.
Also what is on the other side of the shower wall ? Is there a closet or is it the outside wall?
plummen 02-20-2012 08:32 AM
You might be able to get it out of there with a 1/2" drive ratchet with an extension and a deep socket:thumbsup:
hammerlane 02-20-2012 08:32 AM
1 Attachment(s)
In other words if your setup is something like below. You should be able to unscrew #2 from #1
plummen 02-20-2012 08:34 AM
:thumbsup:
hammerlane 02-20-2012 08:46 AM
1 Attachment(s)
Then I would forget about soldering all back in there and buy a brass coupling(5) and a brass nipple(4) if you have the depth and put it all back like that
rrolleston 02-20-2012 09:05 AM
Don't even look like they had that pipe all the way in that male adapter when they soldered it.
Simon96Taco 02-20-2012 08:11 PM
You guys were right - I was able to unthread the piece behind the wall with a socket wrench. I got a brass coupling and a galvanized nipple to replace.
Now I'm dealing with widening the hole so I can get a 1" (or 23mm?) socket through....and having to buy a 1" (or 23mm?) socket ;) I can live with that though.
Thank you all so much for your help.
Simon
plummen 02-20-2012 08:25 PM
TheEplumber 02-20-2012 08:54 PM
199 Attachment(s)
Simon
Better to use a brass nipple.
ben's plumbing 02-20-2012 08:58 PM
take out that male adapter... get longer shower arm no other fittings needed:yes:
Simon96Taco 02-20-2012 09:31 PM
I did try to find brass, but the HD store brass nipple selection were either too short or too long...so the sales guy advised me to use the galvanized piece.
Simon96Taco 02-20-2012 09:32 PM
Great idea! I have to go back to HD tomorrow to buy a socket that fits that coupling, so maybe while I'm there I'll look for a longer shower arm instead ;)
S
