Broken Shower Faucet Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2011, 07:59 AM   #1
DFT
I have a Stanadyne shower system. My cold water faucet handle would spin around and around therefore not turning on the cold water. I removed the lever handle and found a plastic collar that connects the faucet stem to the handle had broken. Where can I get this part?
DFT is offline   Reply With Quote
Old 02-23-2011, 09:55 AM   #2
If you have the ability to turn off the water and remove the valve, take it to a plumbing supply and they can almost always match it. If it is old it may be worth it to replace the entire stem not just the broken piece.
FlipperDave is offline   Reply With Quote
The Following User Says Thank You to FlipperDave For This Useful Post:
DFT (02-23-2011)
Oven handle broken... how to fix steve-19 Appliances 14 11-22-2010 07:34 AM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 09:09 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 12:08 PM
Shower Faucet Repair MsPettus Plumbing 4 05-19-2008 11:39 PM
