Broken Sewer Pipes With Belly - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-30-2010, 08:55 PM   #1
broken sewer pipes with belly
is it nesserary to repair now
chatty is offline   Reply With Quote
Old 07-30-2010, 09:31 PM   #2
Owner
LateralConcepts's Avatar
Depends on the severity of the break and/or belly. I'm assuming you recently had a problem that lead to this discovery?
A minor belly can typically be maintained. A break however, again depending on the severity probably needs to be repaired. "Now"? Maybe, maybe not.
Can you provide more information.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Broken clay(?) sewer line zazz Plumbing 8 02-15-2010 10:12 PM
Belly in main sewer line NailedIt Plumbing 3 11-29-2009 04:19 PM
Broken, busted, clogged storm sewer line... Upstate Steve Plumbing 1 04-07-2009 11:26 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Elevations for outside sewer pipes almostdone Building & Construction 2 04-23-2008 09:49 PM
