Old 10-15-2007, 08:33 AM   #16
Broken pvc pipe
That might work. I bought some other glue so I'll see if that works first. If not, I'll try the tube idea. Thanks!
Keyo77 is offline   Reply With Quote
Old 10-15-2007, 09:12 AM   #17
Broken pvc pipe
I'd buy a pipe tap in a size just too big to slide into the broken PVC. Then tap the PVC that's glued inside the valve. Get a threaded male PVC adapter that's the same size as the tap. Thread it in there with thread sealant, and you're all set. You can then glue a piece of PVC to the MPT fitting, and for pete's sake, install a door stop!
NateHanson is offline   Reply With Quote
Old 10-15-2007, 09:38 AM   #18
Broken pvc pipe
Pipe tap, threaded male adapter, mpt fitting - gotcha. As for the doorstop, I'll let the landlord worry about that. Thanks Nate!
Old 10-15-2007, 10:11 AM   #19
Broken pvc pipe
I'd only let the landlord worry about the doorstop if he's also going to worry about repairing the AC drain next time it breaks (or this time for that matter). If you're going to the trouble to fix this, I'd add a door stop, so all your work isn't wasted when it's broken again a few days later.
I don't know your landlord, but I'd guess a basement doorstop isn't going to be high on his priority list, especially if you're doing the AC repairs for him. What's it going to cost you? 5$
Old 10-15-2007, 08:32 PM   #20
Broken pvc pipe
Just wondering, why is there a valve on your condensate drain?
DuncanB is offline   Reply With Quote
Old 10-16-2007, 09:30 AM   #21
Broken pvc pipe
Nate, I'm getting ready to move so I just want to fix what I broke. I'm gonna let the landlord worry about breaking it again.
Duncan, it's not so much a valve as it is a series of pvc pipes from the condenser coil to the floor drain.
Old 10-20-2007, 04:57 PM   #22
Doing it myself
Alan's Avatar
Broken pvc pipe
Reroute it to the corner of the room so that the door can no longer hit it, if you are able to get it fixed.
Like others, i'm having a hard time picturing this situation. It sounds like you have a floor drain in the middle of your room, and your condenser is draining into it via indirect waste?
Journeyman Plumber
Alan is online now   Reply With Quote
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
