Broken pvc pipe
Daryl, the pic you showed is essentially how the pipe is fitted now so I don't think water build-up would be a problem. I went to Home Depot and the only thing I could find in the way of a glue etc., was plummer's epoxy putty. The package says it can be used as an adhesive for all kinds of things, even underwater and it dries hard. I'm thinking I can mold it around the two broken ends, fit them together and let it dry. I figure at little more than a buck, it's worth a try before I have to go with the drilling and replacing idea.
