Broken Pipe Under Basement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2012, 01:31 PM   #1
Broken pipe under basement floor
I plan to bypass the kitchen outflow pipe running under the cement basement floor but need to insure that waste and water do not backup into that pipe where it connects to outflow pipe when it is out of service. Any suggestions for sealing off the old pipe
Pat Cummings is offline   Reply With Quote
Old 02-12-2012, 02:06 PM   #2
Rewards Points: 13,694
Pipe caps on both ends.
Old 02-13-2012, 03:16 PM   #3
pipe broken under basement floor
I can cap one end easily but other end is under floor and connects to main outflow. do i have to break up floor where outflow from kitchen connects to main outflow in order to cap it?
Old 02-13-2012, 11:11 PM   #4
Yes. And change the Y, or whatever is currently there, to connect to the new drain(s).
VIPlumber is offline   Reply With Quote
Old 02-14-2012, 10:36 AM   #5
I would not bust up concrete just to cut out an old fitting. Put a cap on the pipe coming out of the concrete. I would think that would suffice.
broox is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 08:06 AM
broken pipe under cement atichargr Plumbing 5 04-23-2009 11:15 AM
