Broken Moen Faucet Shower Stem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2012, 05:34 PM   #1
Broken moen faucet shower stem
My moen faucet stem in my shower is broken, which other alternative do i have since there is no way to apply a valve tool?
florida56 is offline   Reply With Quote
Old 01-19-2012, 06:16 PM   #2
Most of the time when I buy a new stem, there is a little plastic piece that you can use to spin the cartridge. Sometimes when you spin it, it loosens up and makes it easier to remove. Sometimes not. Once when I was in your predicament, I got a 1/2 inch drop-in anchor(concrete anchor) and a 1/2 inch eye bolt. I could stick the anchor in the destroyed cartridge, screw the bolt into the anchor while holding backup with a pair of channel locks, and the anchor expanded enough to grab the cartridge and I had something I could hold on to and pull it out with. Of course the cartridge was brass, not plastic. I hope that helps.
broox is offline   Reply With Quote
The Following User Says Thank You to broox For This Useful Post:
florida56 (01-20-2012)
Old 01-19-2012, 07:48 PM   #3
Rewards Points: 14,312
That I know of there's no such thing as a valve tool, a picture would sure help to figure out what it is your trying to remove.
Old 01-19-2012, 08:58 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If the stem pulled out of center of cartridge leaving the outer shell its not too hard to remove them.
Get a piece of 1/4" copper maybe 1 1/4-1 1/2" long ,you may need to experiment with the length.
Anyway push the copper in where the stem would normally go then run a pipe tap into the shell of the cartridge and start threading it into the shell.
It will take a little bit of cranking on the die but once it threads in far enough to make contact with the piece of 1/4" copper it will start pulling the shell out as you keep turning the die in
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 01-19-2012, 08:59 PM   #5
plummen's Avatar
Hes talking about a cartridge puller,that only works if the whole cartridge is there though
ben's plumbing (01-19-2012)
Old 01-19-2012, 10:18 PM   #6
Rewards Points: 582
a picture would help....
Water still coming through faucet when shower is on? homiefb Plumbing 1 08-12-2011 02:45 PM
shower mixing value capping off faucet quetion vote4Pedro Plumbing 1 06-28-2011 03:12 PM
picking a shower faucet vote4Pedro Plumbing 7 05-27-2011 08:56 PM
Broken washing machine faucet Nikroo Plumbing 3 05-09-2009 05:03 PM
Moen faucet repair simonxx Plumbing 2 04-07-2009 08:22 AM
