Broken Handle And Dripping Sound - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2009, 09:14 PM   #1
Rewards Points: 39
Broken handle and dripping sound
1. How can I fix this? The handle broke off with the screw and I don't want to do anything that may make it worse.
2. My kitchen sink makes an annoying dripping sound every time water runs down the drain. Only things that stop it is running more water or plugging off the drains.
Sliding Man is offline   Reply With Quote
Old 04-15-2009, 06:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,.. You need a New faucet,... That 1 looks like it's Junk...
Old 04-16-2009, 01:12 AM   #3
Rewards Points: 39
Its probably been here since the house was built, but I'd hate to have to buy a whole new faucet. No idea what that might cost to buy it then have a pro install it. Also, any advice on the drippy kitchen drain?
Old 04-16-2009, 02:03 AM   #4
Household Handyman
Rewards Points: 1,408
Pardon me, but is that actually the faucet? A picture taken from a little farther back would be helpful also. IF that is the faucet, and IF that is the incoming hot water line running vertical on the left - - could you shut off the water supply, remove the bonnet/hex nut and remove the broken screw from the stem that way? I thought I had seen a lot of older faucet's but that's a new one to me. Good Luck, David
Ductless unit has dripping hose in basement tockfull HVAC 3 07-20-2007 08:17 AM
