Broken Flange? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2013, 06:48 AM   #16
Bill Kearney
Rewards Points: 1,174
One tip when cutting and installing the pipe, do a dry fit first and use a marker to put a line across each joint. This way you'll be able to get it all sorted out FIRST and then be able to set it up that way when you're finally ready to prime and then glue the joints for their final connection. You do not want to be applying the glue until you know how all of it lines up.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Javiles (04-24-2013)
Old 04-24-2013, 07:02 AM   #17
Rewards Points: 2,516
Originally Posted by wkearney99 View Post
One tip when cutting and installing the pipe, do a dry fit first and use a marker to put a line across each joint. .
Yeah good point especially if you have a couple of 45's you have to line up
hammerlane is offline   Reply With Quote
Old 04-24-2013, 08:25 AM   #18
Rewards Points: 556
Originally Posted by hammerlane View Post
which way you going to do the flange??
I was going to try option 2 so I could screw it directly to the subfloor. Then, use a Set-Rite extender to raise it up to the tile level. http://set-rite.com
kcrossley2 is offline   Reply With Quote
Old 04-25-2013, 05:44 AM   #19
Rewards Points: 1,512
This won't help fix the problem but, did you find the missing piece of the flange? That would tell you if the toilet hold down bolts were improperly attached.
Hmmm. If you glued the missing piece back, wouldn't the (essentially welded) joint be just as strong as the unbroken plastic would have been?
Old 04-25-2013, 10:39 AM   #20
Rewards Points: 556
Unfortunately, the broken pieces were discarded. Plus they were too warped to re-glue properly.
Old 04-25-2013, 05:20 PM   #21
Rewards Points: 1,952
Work from the pipe up. Not the flange down. Make sure the flange is securely fastened to the floor with stainless steel wood screws that penetrate the wood floor.
Old 04-25-2013, 05:22 PM   #22
Rewards Points: 556
Won't that make it hard to properly position the flange?
Old 04-25-2013, 05:30 PM   #23
Plumber
TheEplumber's Avatar
Rewards Points: 676
@ kcrossley2-
I saw one of these today at my supply house and I thought of you.
It has all the slots your old flange has. I'm not standing there looking at your's but I'm thinking this might screw down on top of your existing flange and into your sub floor- just a thought- http://www.siouxchief.com/Drainage/R...e-A-Ring.T5FEX
Broken ABS flange on toilet sewer rogerdoris Plumbing 7 12-25-2012 10:27 PM
Broken closet Flange Paul8434 Plumbing 2 12-04-2012 07:08 PM
Broken Cast-Iron Toilet Flange... Pbartender Plumbing 11 08-23-2012 07:59 AM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
