Broken Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2011, 01:30 PM   #1
Broken Flange
While demolishing my bathroom for a remodel due to previous shower leak (shoddy work from previous owner), I removed my loose toilet to find the flange stuck to the bottom of the toilet with what was left of the wax ring. I have never done this type of work and am at a loss. I have 4 grandchildren living with me and really need that bathroom. The flange I believe was cast iron. The pipe you see in the pics are at an angle and a bit jagged. The flanges jagged edges sit just above the slab. There is also an open area of concrete to the left side of the pipe leading to the sewer pipe. Help....please! I have no idea how much that would cost to fix but if it were over $250 I am in trouble. I would appreciate any constructive advise. Thanks!
Size:  27.3 KB Name:  10038744175185_ORIG.jpg
cunnili is offline   Reply With Quote
Old 09-21-2011, 12:14 AM   #2
Plumb or Die!
You're in trouble. Unless you've got experience soldering lead sheeting to repair the lead stub that used to roll over the flange. I see jackhammering, cutting out the old cast iron 90 and replacing it all with plastic, including a new toilet flange in your future.
plumber666 is offline   Reply With Quote
Old 09-21-2011, 11:49 AM   #3
Do you believe this to be a super expensive fix? Nothing I could do temporarily? (I am in between jobs at the moment). This was already broken I think the was ring was just keeping it contained until I removed the toilet.
Tags
flange , plumbing repair , toilet flange , toilet loose
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 11:45 AM
Broken Plastic Toilet Flange ClayS Plumbing 6 01-22-2009 11:02 AM
broken toilet flange brucetackett Plumbing 14 03-14-2008 04:04 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
Best way to fix a broken flange? Tmb9862 Plumbing 8 11-12-2006 05:09 PM
