Broken Electrical Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2011, 08:27 PM   #1
Broken electrical water Heater
I think my water heater is broken because the last few days i have gotten absolutely no hot water and in any faucet or shower and the water is cold.
so yeah... its probably broken. the problem is i know absolutely nothing about water heaters and i have no idea where to start. We also have a mice problem in my house so i wouldn't be too suprised if they were the cause of it somehow. So where should i be checking for damage or problems with my water heater.
Any help would be greatly appreciated.
blackbrawler is offline   Reply With Quote
Old 08-01-2011, 09:14 PM   #2
Rewards Points: 758
First thing, check for power.
Is the circuit breaker tripped? Is there possibly a fused disconnect?
AandPDan is offline   Reply With Quote
Old 08-01-2011, 09:30 PM   #3
Rewards Points: 150
Also, check the upper limit shut off switch. It should be a red button inside an access panel on your water heater.
Broughton is offline   Reply With Quote
Old 08-01-2011, 10:07 PM   #4
I tried turning on and off the circuit board that didn't help.
Old 08-02-2011, 01:19 PM   #5
Rewards Points: 150
Did you try the upper limit shut off switch?
Old 08-02-2011, 07:21 PM   #6
i looked for the switch but its dark in here can you guys give me a clue as to were it is.
update* so i checked out my water heater and it looks like its been leaking a lot of water in and has heavy rust damage may that be the problem, i also still cant seem to find that switch. Here are pictures of the bottom of the water heater.
yeah... things are looking pretty bad.
Old 08-02-2011, 07:36 PM   #7
Rewards Points: 758
It's under the top cover. You'll have to remove it so make sure you turn off ALL power to the water heater first. It should be a red button and usually they say "reset" on them.
After you press it, put the cover on and turn on the power.
Never mind, just saw your pictures. Looks like you need a new water heater.
Old 08-03-2011, 07:38 AM   #8
Just call me Andrew
Rewards Points: 1,020
Turn off the incoming water to the heater immediately and get a new heater. I saw water around my water heater a couple years ago, and the leak burst within a few days and left me with 750 gallons of water in my basement.
Andrew
secutanudu is offline   Reply With Quote
Old 08-03-2011, 06:23 PM   #9
Household Handyman
Rewards Points: 1,408
All the damage you have shown was caused by one or more water leaks. Each water leak is a potential time-bomb just waiting for you to go somewhere for a few days so the rusted metal can split just a little bit and flood you home. Do look into a replacement heater unit.
low pressure after hot water heater replacement tuffluck Plumbing 4 06-07-2011 03:14 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
