Old 02-23-2012, 01:57 PM   #1
broken drain pipe in stack
broken gal,metal drain pipe inside of vent stack. threads left inside limted access. help,,,,
mike10 is offline   Reply With Quote
Old 02-23-2012, 03:55 PM   #2
call me E
TheEplumber's Avatar
gently sawzall through the galvanized threads until you hit the female threads. Then chisel out the broken threads. Remove all the remaining gal. drain pipe possible. It's toast.
Old 02-23-2012, 05:45 PM   #3
images would help determine the repair method.
COLDIRON is offline   Reply With Quote
Old 12-29-2012, 04:36 PM   #4
Mike
Not clear if the broken pipe is acting as a drain or a vent. Vent pipes positioned 6 inches above the flood rim of a fixture are technically a vent and if not wet vented are air vents and only subject to probably rain water Having said that not knowing the why's of it breaking you can cut a small say 2 inch section out of the pipe and repair with a hubless connector or fernco This would be for a straight pipe break not where drainage fitting are located
mr leak is offline   Reply With Quote
Old 12-29-2012, 04:44 PM   #5
At some point steel pipes will always leak, close up on the inside or fail in some way.
Might be a good time to bite the bullet and replace it all with PVC.
Old 12-29-2012, 04:48 PM   #6
call me E
Hopefully, this has been repaired in the last 10 months
Old 12-29-2012, 06:39 PM   #7
Master Plumber
Javiles's Avatar
Somebody started early with the apple cider.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 12-29-2012, 07:00 PM   #8
Roofmaster
Was your battery low when you made this inquiry?
How about some pictures? This is almost 2013.
" A lot of men build things, and a lot of things fall down "
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 01:28 AM
Utility sink drain pipe question jabergess Plumbing 3 05-06-2011 09:01 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 06:19 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
