Old 09-07-2008, 05:17 PM   #1
Broken Diverter? Need HELP! URGENT!!!
hi, i think my shower diverter is broken. it is on top of the tub spout/facuet. what will happen is when i pull the diverter up to put it on shower mode half of it will be on shower and half of it will be on bath. i think i need to replace it but i dont know how for the only way it seems i would have to replace it would be by pulling out the entire tub spout. URGENT! NEED HELP AS SOON AS POSSIBLE! very confused
heres some pictures of the tub spout and diverter on top of it:
esadiek is offline   Reply With Quote
Old 09-07-2008, 06:33 PM   #2
the Musigician
DangerMouse's Avatar
i believe if you get a good grip on that with both hands and turn it counter-clockwise, it'll come off, that's a normal looking spout to me. check the bottom first to see if there's a set screw (allen). if so, loosen or remove it first. then just go to any bigbox or local hdwr store and buy another. follow simple directions and install. =o)
DM
Old 09-07-2008, 09:31 PM   #3
Moderator
Termite's Avatar
As dangermouse said, it should unscrew counterclockwise. Installing a new diverter should fix your problem and is not a difficult task.
Tags
broken, diverter, faucet, shower, tub spout
broken lug studs LanterDan Automotive Repairs 19 02-01-2009 09:13 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
Bathtub tub spout Diverter broken? tripower Plumbing 5 06-24-2007 07:44 PM
Broken Drill Bit Freelancer General Discussion 15 03-29-2007 05:01 PM
Broken Brake Shoe powrus Automotive Repairs 11 01-16-2007 06:40 PM
