Broken/cracked Kitchen Drain Line Under House - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-14-2012, 01:09 PM   #1
Broken/cracked kitchen drain line under house
Hi everyone! Need some plumbing advice.
It appears that our kitchen drain line is cracked or broken underneath the foundation. The line runs back from the sink, down through the basement and into the foundation (we've checked the line between the basement floor up to the sink, so we are pretty sure that the issue is underground). We are also pretty certain that it's just the kitchen drain, and not the sewer main (none of the other drains/sinks/toilets in the house have been backing up or drain slow at all). Rather than tearing up the foundation, we are wanting to just run the kitchen line from where it comes through the basement ceiling and connect it to one of the big 3" drain lines.
So, my question is what is the best way to cap the kitchen line that runs into foundation? Should we cut it down and cement over it? Install a cap? Is there a possibility of future issues with a "dead line" under the house that's possibly broken still connected to the sewer main?
Thanks in advance for anyone's advice!
Josh
joshua1978 is offline   Reply With Quote
Old 09-14-2012, 02:50 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
What makes you think it is broken under the floor? It just may be clogged. Install a clean-out above the floor (if one does not exist) and have the line snaked or jetted. A camera inspection will very if it is broken or not.
Coastal South Carolina
Old 09-14-2012, 03:15 PM   #3
There is a cleanout installed. We've had a plumber out to unclog it once and he was bringing up mud and clay and suggested there was probably a problem with the line. Two months later it was backing up again. I snaked it out this time and was bringing up the same stuff. We've also had a few different plumbers out for estimates/opinions. We are pretty confident the issue is under the house.
Old 09-14-2012, 04:38 PM   #4
A "Handy Husband"
rjniles's Avatar
I still think a camera inspection will give you a definitive answer.
Old 09-14-2012, 04:59 PM   #5
cut it a few inches above the cleanout and glue a cap on it.
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 09:32 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Fittings for kitchen sink drain line banjo Plumbing 4 04-24-2011 09:19 AM
Kitchen remodel, sink drain rework pinkertonpv Plumbing 3 02-18-2009 10:06 AM
