Broken Cartridge Stem - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2011, 12:20 AM   #1
Hi all.....a customer of mine broke the stem off of her cartridge. It's a Moen single handle shower cartridge. Any ideas on how to get that sucker out so we can replace the cartridge?
Glenn12 is offline   Reply With Quote
Old 06-19-2011, 06:50 AM   #2
DIY staff
Rewards Points: 7,174
That's ugly.I've never run into that----My helper did,however and the solution involved a pair of long nosed Vice Grips and a drill.
He was successful and is now a firm believer in the use of a Moen valve pulling tool.
Old 06-19-2011, 08:03 AM   #3
Moen provides a little plastic stem tool in the package with the new stem. After the retainer clip is pulled out, the tool slips in on either side of the old stem; then you twist it out with a wrench or pliers.
Ishmael is offline   Reply With Quote
Old 06-19-2011, 10:26 PM   #4
Hi Gentlemen:
Thanks both for the replies..I think I'll try needlenose vise grips and if that doesn't work, out comes the drill and tap.
I don't think a plastic thingy will get that cartridge out...I pulled the clip, then tried prying/twisting etc, even with water pressure on (oy!).
Darn thing wouldn't budge.
I guess getting this one solved will make me just that much better....eh?
Old 06-20-2011, 07:07 AM   #5
DIY staff
Good luck--
Old 06-20-2011, 07:09 AM   #6
Rewards Points: 1,528
Could you drive a screw into it and pull on the screw? (Don't go too deep).
bob22 is offline   Reply With Quote
Old 06-20-2011, 07:12 AM   #7
DIY staff
I'd try drilling out as much of the cartridge as I could--being careful not to damage the valve body--
Old 06-20-2011, 08:00 AM   #8
Nipple extractor?
Old 06-20-2011, 10:52 PM   #9
Thanks all for your suggestions and replies. I ended drilling as much as the body as possible, until I could pull out the broken stem/valve itself. Once I got the valve and the two rubber gaskets (?) where the hot and cold enter, I was able to get the rest of the cartridge out fairly easy.
Sheesh...what a pain...
Anyway, it can be done, but as Mike said, BE VERY VERY careful you don't mar the brass valve body where the cartridge is mounted. It is soft and easily gouged or scratched.
Alls well that ends well.
Thanks again.
The Following User Says Thank You to Glenn12 For This Useful Post:
oh'mike (06-21-2011)
Old 06-21-2011, 06:56 AM   #10
DIY staff
A Moen valve pulling tool is a good value.
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 03:42 PM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
how to recognize the new or old bathtub faucet cartridge jeand Plumbing 2 12-18-2010 02:27 PM
broken ball valve stem Doc O'Connor Plumbing 6 09-11-2010 10:08 AM
broken moen bath/tube cartridge M. A. Mendez-Ch Plumbing 1 06-03-2010 02:59 PM
