Broken Ball Valve Stem - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2010, 01:07 PM   #1
I have a 2" brass ball valve on my pool. The stem and handle are broken off. Is it possible to buy a replacement stem & handle? The whole valve costs $80; so I'm trying to save some money. How is it installed?
Thanks, 'Doc'
I have a 2" brass ball valve for my pool. The valve stem and handle are broken off. Can I buy replacement parts? How to install? Thanks, Doc
2 threads on same issue merged
Moderator
Doc O'Connor is offline   Reply With Quote
Old 09-06-2010, 03:33 PM   #2
lloydb's Avatar
Could you take a picture of it and post? Hard to say how it's installed without looking at it.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 09-07-2010, 05:47 AM   #3
Did you misread your post? This is painting not plumbing. Try to re-post this in plumbing forum.
mark942 is offline   Reply With Quote
Old 09-07-2010, 08:41 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 682
@ Doc, replace the valve
Old 09-07-2010, 12:23 PM   #5
The valve is $80 and sweated on. So I'm looking for an easier solution, since it is not critical and no great pressure. Doc
Old 09-11-2010, 02:02 AM   #6
WDR
valve
Check mcmaster carr item # 47865K58 $52.27 Every thing I have orderd shipped fast and for cheap. Allso dose a lot of chlorine touch the valve, I have seen brass pipes on pools become extremley britle from contacting a lot of chlorine.
WDR is offline   Reply With Quote
Old 09-11-2010, 09:08 AM   #7
DIY staff
Rewards Points: 7,174
You would need to remove the valve to open it ---there are two halves that are screwed together to encapsulate the ball-----
Seriously they are not intended to be rebuilt-----We used to take the 4" valves apart to scrap the brass.--Mike--
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Is this gas ball valve safe? nutlog Plumbing 17 12-23-2008 01:40 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
