Broken ABS Pipe Under Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2013, 12:52 PM   #1
Rewards Points: 12
Unhappy
Broken ABS pipe under closet flange
I'm setting a toilet for our new basement bathroom. When cutting the pipe (3" ABS), so the flange is at the right height, the pipe broke. Is there a way to fix this without having to break the floor up?
The pipe is attached to a flexible coupling that was used to extend the pipe from the existing drain. Above the coupling, there's only about a 1/4" of pipe (at the lowest point). I'm not sure if using a reamer bit is possible (or recommended) so I can ream out the existing pipe and insert a new piece.
djinlondon is offline   Reply With Quote
Old 09-26-2013, 03:51 PM   #2
Rewards Points: 352
loosen the hose clamp and pull the broken pipe out
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
djinlondon (09-27-2013)
Old 09-26-2013, 05:23 PM   #3
Rewards Points: 1,870
Break out the concrete...
What is the Styrofoam on the floor for?
That stuff is way to soft to set a fixture on.
Tags
abs , concrete , flange , plumbing , toilet
Cast iron closet flange help... Inset pipe? 7freedomsfarm Plumbing 3 05-08-2013 11:00 AM
Toilet flange question clambake6 Plumbing 18 03-07-2013 09:25 PM
closet flange extension BlueBSH Plumbing 2 09-27-2012 09:58 AM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 10:45 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
