Old 09-12-2010, 12:47 PM   #1
Broke shut off valve?
My toilet started leaking. In order to test where is was leak from I turned the toilet water shut off valve off. The water stopped, I was able to check the flopper and determined that was not the problem. I turned the valve back open, but the water does not come back.
I am thinking that the internal part of the valve broke when I tried to turn it back on...does this sound right? Does anyone have any other ideas what could have happened?
rmartin66 is offline   Reply With Quote
Old 09-12-2010, 12:57 PM   #2
fill valve or angle stop. Take the supply line off the fill valve, put it in a bucket, and turn the stop on. If water comes out, replace the fill valve. If not replace the angle stop. If the valve doesn't completely shut off, replace both
the_man is offline   Reply With Quote
Old 09-12-2010, 01:01 PM   #3
It is an angle valve, I am at work right now, as soon as I get home I am going to town on it.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 04:34 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
