Old 09-30-2009, 12:46 PM   #1
Default bread still suspected stuck at the tap
i had to stuff a lot of bread into the copper pipe last night to stop leaks from getting to where i was soldering.
but it took an awful lot of time for the water to break through it and start coming through the tap. like 15 min of the tap being turned on.
even then, the water pressure is considerably lower, as though there is still bread in the tap or something. this is at the kitchen sink. can i expect that it will eventually dissolve over time ?
i didn't use the plainest plain white bread, like WONDER or some other cheap alternative, which i understand is the best for this, i actually used my favorite sourdough bread from trader joe which has a different texture but still no grains on it or something that would be harder to dissolve.
Old 09-30-2009, 01:08 PM   #2
Have you taken the screen/aerator off the tap?
jerryh3 is offline   Reply With Quote
Old 09-30-2009, 01:09 PM   #3
yes and cleaned it but still.
Old 09-30-2009, 01:12 PM   #4
While this method works, if you have a single handle faucet, some of the bread may be lodged in an "O" ring in the cartridge.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-30-2009, 01:21 PM   #5
yesir, it's a single handle faucet. where do i go from here ?
Old 09-30-2009, 01:26 PM   #6
Turn off the water supply valves and look for an allen screw or maybe a large nut at the base of the spout that holds the spout on. Remove the spout and you should be able to pull the cartridge out. Mark the top edge first so you reinstall it in the same position. If there is bread stuck there, you should be able to see it and rinse it out.
Old 09-30-2009, 01:31 PM   #7
thanks
Old 09-30-2009, 08:27 PM   #8
Joe F's Avatar
You can try disconnecting the supply line at the valve under the sink. Open up the valve (with a bucket or towel) and see what kind of pressure you have. This will tell you which side of the valve that the "clog" is on.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-02-2009, 06:42 PM   #9
Default Seeded rye
I used seeded rye one time, man what a problem I had. Not really just throwing in a little humor.
SULTINI is offline   Reply With Quote
More On This Topic
Hey there, again. We've got another fermented food. I know, you can't believe it. There's so many. But, we're just going to do the main ones of course. Next one is sourdough. And, it's actually warming up in my oven right now because, I love warm bread... Read More »
There are no eggs in this recipe; but you'd never know it with all the flavor. Read on to learn how to make a new gift or a more healthy family snack. Read More »
Alright we have our sour dough bread and how this is so much more healthy. Why is it more healthy? Why is this much more beneficial than the other whole grain bread that I buy or that you buy I should say because I don't do it? Anyway, the big thing is... Read More »
On this next clip we're going to be talking about the ingredients that will be used in the vegan stuffing. They can be fresh or dry. I'm using both, both mixed. I prefer fresh but this time around I did not have it all available. I'm going to be using... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
Stuck Snake frederick70 Plumbing 22 05-13-2009 07:01 PM
stuck in the middle sninny General Discussion 9 04-08-2009 01:24 PM
drain stuck how to remove tverhoef Plumbing 1 03-14-2008 07:53 PM
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 22 11-20-2007 07:56 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 07:29 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
