Old 06-18-2010, 06:11 PM   #1
brasscraft basin wrench
Hello All!
I purchased a T151 brasscraft basin wrench today. There are no directions on how to adjust the head. There's a small hole in the side which I suspect is used to release a pin, but I can't figure it out.
Thanking you in advance.
momof2labs is offline   Reply With Quote
Old 06-19-2010, 08:23 AM   #2
the head flips over for different directions. Don't take that pin out. Unless you use the tool quite a bit, you will need some time to get it right. You most likely will be lying on your back under the sink looking up. turn to the left to loosen, to right to tighten. It will seem everything is in your way but you can work around it.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
The Following User Says Thank You to DUDE! For This Useful Post:
momof2labs (06-19-2010)
Old 06-19-2010, 09:08 AM   #3
the Musigician
DangerMouse's Avatar
Basin wrenches can be a real lifesaver when working on SOME sinks....
I have a basin wrench "head" that snaps on any 3/8" extension and ratchet wrench. Po)
It's come in handy more than once, that's for sure.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 06-19-2010, 02:31 PM   #4
Smile
I finally got it! It's v e r y tight to flip over. Thanks so much.
Old 06-20-2010, 09:51 AM   #5
Owner
LateralConcepts's Avatar
It's easy to get turned around and forget which way is lefty loosy and righty tighty when you're laying on your back under a sink with a tool that doesn't look like anything else in your arsenal. The easiest way to tell which way it should be flipped is by simply grabbing your finger with the tool and give it a little twist before maneuvering through a maze of pipe and supply lines
LateralConcepts is offline   Reply With Quote
Old 06-20-2010, 11:10 AM   #6
Excellent point! Things don't look the same when you're under the sink, do they? Thanks again.
Tags
basin wrench, brasscraft
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 05:30 AM
Help with Impact and Ratchet Air Wrench Comparison, Confusing Specs don’t match caliskier Tools 5 03-15-2009 11:33 PM
what wrench for a radiator fitting drewhart HVAC 9 01-07-2009 05:04 PM
spud wrench problem drewhart HVAC 3 01-06-2009 09:41 PM
Catch Basin sebas54 General Discussion 2 07-13-2008 10:38 PM
