Brass Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2010, 07:33 AM   #1
Brass shut off valve
My dad has a brass shut off valve. He bought a plastic concection that screwed into the brass and the copper tube went into the other end. I turned the water and the copper tube sprayed all over. Can I put something on the copper or do I need try something else?
Gary W is offline   Reply With Quote
Old 11-27-2010, 09:45 AM   #2
Not sure why the connection was plastic. You need to switch that out and install a copper or brass fitting with a compression fitting or solder it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-28-2010, 12:41 AM   #3
the plastic extension is what my dad bought to connect the shut off to the copper tube. Thank you.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 02:22 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 03:34 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 12:02 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
