-   -   Brass shut off valve (http://www.diychatroom.com/f7/brass-shut-off-valve-87840/)
Gary W 11-27-2010 08:33 AM
My dad has a brass shut off valve. He bought a plastic concection that screwed into the brass and the copper tube went into the other end. I turned the water and the copper tube sprayed all over. Can I put something on the copper or do I need try something else?
majakdragon 11-27-2010 10:45 AM
Not sure why the connection was plastic. You need to switch that out and install a copper or brass fitting with a compression fitting or solder it.
Gary W 11-28-2010 01:41 AM
the plastic extension is what my dad bought to connect the shut off to the copper tube. Thank you.
