Brass Plated Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2008, 02:37 AM   #1
Rewards Points: 528
Hello,
Some of my bathroom fixtures such as soap dish and cup & toothbrush holders are brass plated and I noticed that they corrode after a few years and that I believe that they are foreign made. I also have a solid brass showerhead by Delta that is 15 years old and shows no signs of corrosion. It appears that brass plated fixtures do not hold up well vs solid brass fixtures. Are plumbers of the same opinion?
I just replaced the faucets in my two bathrooms with solid brass polished ones and I like to know if its safe to apply butchers wax for added protection. The manufacturer's only recommend cleaning with a damp cloth, but over time, the protective finish will probally break down and is not noticeable until the brass starts to show surface marks. What products will give me good protection that will not affect the protective coating?
rjordan392 is offline   Reply With Quote
Old 06-19-2008, 08:29 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Do as the manufacture says to do, or you could void any warranty.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-19-2008, 03:33 PM   #3
Rewards Points: 528
I forgot about possible voiding of warranty. Will do as you advise. But will continue to upgrade my fixtures with solid polish brass as I had it with the plated ones. More expensive up front but cheaper in the long run. I tracked down the manufacturer of the plated soap and toothbrush holder and found that they are zinc alloy underneath the brass finish. These plated products do not hold up.
Old 06-19-2008, 03:50 PM   #4
Registered User
Termite's Avatar
Perhaps there is a clear laquer applied over the finish of the fixtures that have held up?
Old 06-19-2008, 04:08 PM   #5
Think about it, does your showerhead get the same amount of cleaning as the rest of the fixtures? Even though solid brass is better, I doubt you used the same cleaning compounds on the showerhead, or as often, as you did the other parts.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-19-2008, 09:19 PM   #6
Rewards Points: 528
Yes, once the laquer coat gets scratched, then discoloration begins.
I have used Lysol Bathroom cleaner a few times on the plated brass. I don't remember if I ever cleaned the solid brass showerhead or the plated robe hanger and the robe hanger has some discoloration. That and the soap dish and toothbrush holder will be replaced soon and in the future, I will keep all my brass wiped down with a damp cloth.
replacing brass shower fixtures; how hard? tarheelblue Plumbing 6 01-26-2008 08:18 PM
Good place to buy decent fixtures? twilightcall Plumbing 3 01-23-2008 07:23 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 02:40 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
