Old 01-22-2013, 04:15 PM   #1
Brass Overflow/waste tail pipe to PVC
Hey guys,
I have a Brass Tub Waste/overflow 1-1/2" tail piece that I need to connect to a solvent pvc trap. Recommendations?
Rubber band type union?
Its all in a crawl space so there is access.
Bama is offline   Reply With Quote
Old 01-22-2013, 04:21 PM   #2
Got a picture?
http://www.bing.com/images/search?q=...electedIndex=8
They make them in male and female.
Old 01-22-2013, 04:22 PM   #3
call me E
TheEplumber's Avatar
Use a PVC trap adapter- just like on a Ptrap connection. They're available with or without a hub
Old 01-22-2013, 07:13 PM   #4
Thanks All!
Old 01-22-2013, 07:28 PM   #5
Roofmaster
Id use a fernco rubber coupling on that. Too much dissimiliar movement between brass and plastic with temp swing.
" A lot of men build things, and a lot of things fall down "
Old 01-22-2013, 08:35 PM   #6
call me E
Seriously? On a W&O assembly? Do you use them on tubular brass lav traps joined to plastic plumbing systems?
Old 01-22-2013, 09:43 PM   #7
Roofmaster
Just posting a possible concern. Im not a professional Plumber like you. I assume you are referring to thin wall brass vis a vis the breeze clamp?
I do know that brass moves at a much different rate than plastic, but defer to the pros here, if it is known to perform. I have never had much long term luck with those Nylon integral washers.
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 09:59 AM
shortening bathtub drain tail pipe amakarevic Plumbing 2 11-29-2011 09:34 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
brass pipe thread loosening Gerald Plumbing 3 03-02-2006 11:40 AM
