-   -   Brass Overflow/waste tail pipe to PVC (http://www.diychatroom.com/f7/brass-overflow-waste-tail-pipe-pvc-169838/)
Bama 01-22-2013 03:15 PM
Hey guys,
I have a Brass Tub Waste/overflow 1-1/2" tail piece that I need to connect to a solvent pvc trap. Recommendations?
Rubber band type union?
Its all in a crawl space so there is access.
joecaption 01-22-2013 03:21 PM
Got a picture?
http://www.bing.com/images/search?q=...electedIndex=8
They make them in male and female.
TheEplumber 01-22-2013 03:22 PM
199 Attachment(s)
Use a PVC trap adapter- just like on a Ptrap connection. They're available with or without a hub
Bama 01-22-2013 06:13 PM
Thanks All!
jagans 01-22-2013 06:28 PM
Id use a fernco rubber coupling on that. Too much dissimiliar movement between brass and plastic with temp swing.
TheEplumber 01-22-2013 07:35 PM
199 Attachment(s)
Seriously? On a W&O assembly? Do you use them on tubular brass lav traps joined to plastic plumbing systems?
jagans 01-22-2013 08:43 PM
Just posting a possible concern. Im not a professional Plumber like you. I assume you are referring to thin wall brass vis a vis the breeze clamp?
I do know that brass moves at a much different rate than plastic, but defer to the pros here, if it is known to perform. I have never had much long term luck with those Nylon integral washers.
