Brass Hex Nut Stripped & Needs Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2014, 10:10 PM   #1
Brass Hex nut stripped & needs replacement
This is a Grohe shower fixture, I had to replace the Check Valve & was able to do it easily for the cold water side. However the Hot water side the Hex nut is completely stripped. I tried to use an extractor & that broke inside. Any idea on How I could remove. I have no problems damaging the old check valve.
Will adding some solder around the hex nut help out to give some grip to loosen it? Any body tried this idea?
The part number on Grohe is 47 477
thinkfuture is offline   Reply With Quote
Old 06-13-2014, 11:09 PM   #2
Rewards Points: 6,652
Go to Ace or Sears and get the Craftsman Extractor kit in the tool aisle. This is what happens when people do not lube the threads with Plumber's grease or 3:1 oil on the threads.
Old 06-13-2014, 11:14 PM   #3
I got an extractor kit, darn thing broke inside. There's no more thread in there either.
Old 06-13-2014, 11:16 PM   #4
Rewards Points: 1,682
Once a screw extractor is broke off in anything, the chore is hopeless, or so expensive that you will wish that you just replaced the whole assembly.
And I speak from experience, I once spent $350, to have something repaired after the extractor broke in it, when I could have bought new for $35.00.
So my advise is to replace the entire shower assembly. Call it good riddance and be happy.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
plummen (06-16-2014)
Old 06-13-2014, 11:25 PM   #5
ED
NOOOOO....that's the dreaded news. This would mean I have to remove the tile around that section & seems like a HUGE deal.
Will Soldering Lead into that hole along with a Hex give some grip?
Old 06-14-2014, 05:28 AM   #6
Rewards Points: 13,450
Not going to work, solders to soft.
Time for a new valve.
Most often there removed from the back side not the tiled side.
Old 06-14-2014, 05:45 AM   #7
Rewards Points: 22
This probably won't work but it beats changing the valve. Find a bolt about the size of the stripped hole and super glue it in. Spray penetrating lube around the threads for the valve a few times. Use a wrench on the bolt.
Dan
djlandkpl is online now   Reply With Quote
Old 06-14-2014, 06:41 AM   #8
DIY staff
Rewards Points: 7,174
What holds that valve into the valve body? Could you snap a picture from the back side?
Does it screw in ?
Old 06-14-2014, 06:58 AM   #9
DIY staff
post the part number or something that will allow me to see the PDF for that valve
Old 06-14-2014, 07:04 AM   #10
Rewards Points: 472
he posted this The part number on Grohe is 47 477
del schisler is offline   Reply With Quote
Old 06-14-2014, 07:10 AM   #11
DIY staff
Thanks--that thing screws in---forget the bad hex hole---
Get an adjustable spanner wrench--drill two holes in the face of the stuck part--the correct size for the spanner pins---stick the spanner on the stuck valve and unscrew it---
wkearney99 (06-14-2014)
Old 06-14-2014, 08:05 AM   #12
Bill Kearney
Rewards Points: 1,174
What Mike sez. I was thinking along the same lines. I've heard them called pin wrenches or a face spanner. One like this comes to mind:
The idea is you drill two holes into the face of it and use the pins on that kind of wrench to twist it out.
Next question, what's on the wall behind that mixer valve? Because it's often a LOT less trouble to come in through the back instead of busting up tile...
wkearney99 is offline   Reply With Quote
Old 06-14-2014, 08:27 AM   #13
Rewards Points: 642
Last resort may be to drill and/or grind it out and replace with new valve. Don't touch the threads. The crack is a weak spot.
Learned from auto repairs, but sometimes tightening just a little to break the fused threads then repeating screw/unscrew helps.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
oh'mike (06-14-2014)
Old 06-14-2014, 03:48 PM   #14
Rewards Points: 3,280
Much the same idea as the pin wrench when you don't have a pin wrench. Drill a couple holes opposite each other into the cartridge as far apart as you can without hitting the threads (3/8 inch would be nice if you have the room. Slide a couple of 3/8 bolts into the holes leaving a couple of inches of bolt exposed, then stick a pipe between the bolts and twist. A little heat from a torch may help, but careful not to heat too much.
Bob Sanders is offline   Reply With Quote
Old 06-14-2014, 05:14 PM   #15
Those spanners can be purchased at any bike shop.
Sash Replacement vs. Insert Window Replacement dcd22 Windows and Doors 15 07-27-2014 04:39 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
replace replacement windows theone Windows and Doors 3 10-19-2011 09:16 PM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 09:16 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
