Brass Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2009, 11:38 PM   #1
brass flange
What is the proper instalation method for a brass flange plus lead riser?... it will be on top of tiles, do i drill holes in the tiles for the bolts?... also i know how the bolts that connect to the toilet go, but what kind of bolts do i need to anchor the flange to the floor?
scotty123 is offline   Reply With Quote
Old 02-19-2009, 06:39 AM   #2
Remodeling Contractor
Use whatever type of bolts that work to reach the wood sub flooring below. You need a solid footing for the ring, since the joni-bolts hold the tank are only held by this ring. You do need to go through the tile. Normally the tile would have been cut around this ring.
Old 02-19-2009, 08:59 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
They make tile bits but I've always just used a masonry bit and a hammer drill on slow speed for going through tile. Once you get past the glaze drilling is easy. Let me preface that by saying that on something that is exposed I will use the tile bit and a regular drill. However, the flange is under the toilet and not exposed so the masonry bit would be my preferance. Use screws that are not going to rust such as brass. Be sure the screws are long enough to bite into the subfloor well to give you a solid installation.
JDC is offline   Reply With Quote
Old 02-20-2009, 07:24 AM   #4
Thank you guys, very helpful.
Old 02-20-2009, 01:59 PM   #5
Rewards Points: 562
first off,,get rid of the lead flange,,,its prone to leaking and soft,and outdated. A plastic flange has the proper holes
4just1don is offline   Reply With Quote
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 06:51 PM
cast iron flange Jrebhun Plumbing 2 09-06-2008 01:45 PM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
