Old 04-01-2010, 09:52 AM   #1
Question
Brass fittings with Pex
I have recently built a new house. We moved in Sept 1 2009. Since moving in, we have had 4 brass 90 degree elbows in our water lines break causing considerable water damage. The break always occurs in the same location.
We used a large plumbing contractor in our area who has not experienced these kind of issues in other homes they have worked and they didn't have new personnel working on the project. The fittings that failed "appeared" to have been installed properly but one can never tell if stress was placed on the opposing side of the 90 degree elbow during installation that resulted in cracking.
We have a well and acidic water with high iron content that is treated with a water softening and filter system.
We are struggling with how to proceed at this point. Any experience with this type of issue? Any advice would be appreciated.
trijack3 is offline   Reply With Quote
Old 04-01-2010, 02:35 PM   #2
replace them with teh plastic type fittings. some areas with poor water quality have had the brass fittings brake. what brand pex and fittings do you have?
plumber Jim is offline   Reply With Quote
Old 04-01-2010, 10:48 PM   #3
Doing it myself
Alan's Avatar
Seconded. We only use plastic fittings EXCEPT for adapter fittings.
Journeyman Plumber
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 08:33 PM
Pex fittings brass vs plastic theedudenator Plumbing 5 02-03-2010 09:58 AM
Joint compound on brass fittings for natural gas? larrycassidy Plumbing 5 07-13-2009 09:31 PM
3.5'' Brass Drain cleanout cover jeffmn Plumbing 6 01-13-2009 08:37 AM
Brass Plated Fixtures rjordan392 Plumbing 5 06-19-2008 10:19 PM
