Brass Fitting Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2011, 07:28 PM   #1
Brass fitting removal
Need a tool suggestion for removing a brass fitting. U can see the brass end below. The male end is in the female end just left of the valve. It's in there pretty good andy wrench can't get it loose. Any recommendations would b appreciated (preferably a tool available at Lowe/HD)
starkhd is offline   Reply With Quote
Old 12-08-2011, 07:50 PM   #2
Use a pipe wrench on it. Buy 2 larger ones 10 or 14 inch maybe. Use one to support the pipe you don't won't to remove and twist the other one to remove the fitting.
Go to HD in the plumbing isle they sell Ridgid pipe wrenches. If you plan on doing this stuff buy Ridgid pipe wrenches you will have them the rest of your life.
rodm1 is offline   Reply With Quote
Old 12-08-2011, 07:56 PM   #3
biggles's Avatar
is that a live valve with something on the closed side..or just on the floor ...if on the floor set up adjustable on the valve holding the fitting threads and then a pipe wrench on the fitting just opposite on the wrench handles and jerk them it will break loose...note the directions of the hold back and the wrench breaking direction.if that is a loose setup heat on the thread part will help it if there is sealer holding it
Old 12-08-2011, 08:55 PM   #4
Thanks. I'll pickup the wrenches tomorrow.
It is a live valve.
Old 12-08-2011, 09:07 PM   #5
biggles's Avatar
if your doing it with channel locks maybe one but the hold back has to be a wrench pipe or adj...you'll get it
Old 12-08-2011, 11:09 PM   #6
Pipe wrenches for 1/2" pipe? You're kidding right? A 6" & 8" adjustable crescent, maybe 8" & 10" at most.
VIPlumber is offline   Reply With Quote
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 10:06 PM
Brass Fitting Broke Flush on Air Compressor C_J_GO Tools 5 08-04-2011 11:29 AM
CPVC lines with brass fitting mill1500 Plumbing 5 05-19-2011 10:43 AM
Brass fitting help Joe F Plumbing 3 09-22-2009 10:57 AM
How long to heat the brass fitting jgs1951 Plumbing 2 07-22-2009 10:19 PM
