Brass fitting help
thats not the correct fitting for purging are from you heating system. Let me look for a picture of the correct way.
this is a baseboard tee. On the 1/8" threaded side you install a bleeder valve designed just for what you want to do. this fitting would replace one of the elbows on your baseboard.
http://images.google.com/imgres?imgu...WfNYrSsQPr281b
the bleeder valve looks like this. sorry this is the best picture i can find online. its the chrome piece. it would thread into your baseboard tee.
http://img518.imageshack.us/i/img0073yi9.jpg/#q=base board bleeder valve heating
I would also ask the Hvac people what they think. why do you need one? do you not have something to automaticly remove the air in the lines? a scoop etc.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
