Brass Drain Body And Cast Iron Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2013, 11:59 AM   #1
Brass Drain Body and Cast Iron Flange
I have a jasom brass drain body and cast iron flange in a standup shower that I need to remove. The flange is very rusty and I can't tell how the drain body is attached, either screwed on or soldered? I have a leak somewhere that is seeping into the subfloor around the flange and dripping down to the kitchen below. There is tile around the drain. Do I need to start removing the tile to get at the drain? I am not sure where the leak is coming from exactly, I am guessing from around the flange somewhere. Do I need to replace the flange, drain, and trap?
LeakyPete is offline   Reply With Quote
Old 12-07-2013, 01:23 PM   #2
Rewards Points: 1,706
Looks like its time for a complete shower redo...
Old 12-08-2013, 12:01 AM   #3
Rewards Points: 616
it could be the tile not the drain. i would pour water down the drain from a bucket to make sure it is the drain. if no leak then plug drain and fill bottom of shower up with 2 to 3 inches of water and see what happens. could also be shower head pipe
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Tags
drain , shower leaks
