Brass To Copper Solder - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2012, 09:30 PM   #16
When testing shower heads I use one of these,
It's called a handiplug and runs for under $5.
VIPlumber is offline   Reply With Quote
Old 09-12-2012, 09:41 PM   #17
Rewards Points: 131
Two steps forward and one step back. I have the shower assembly pretty much ready to go but, the water shut off valves were stuck. The hot water valve is now working properly and the cold water valve is still being worked on.
wwkayaker is offline   Reply With Quote
Old 09-15-2012, 04:59 PM   #18
Rewards Points: 131
Okay, I turned the water on to test my plumbing and there are no leaks woohoo and I am relieved. But, how long should I wait to to be certain that my plumbing is good or is it unlikely that anything will begin leaking now?
My solder joints are not pretty and I am slow but, it seems to be good.
Old 09-15-2012, 05:16 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 904
Two types of solder leaks- one sprays a little pisser stream
The other seeps very slowly.
Although you can tell almost instantly, wipe your joints with a paper towel after a couple hrs. If no moisture your good to go
Old 09-15-2012, 05:23 PM   #20
Rewards Points: 131
Thanks eplumber. I have the joints wrapped with toilet paper now to see if I get any moisture. If I do get a leak, what is the method for fixing a joint? Do I just heat it again and add solder?
Old 09-16-2012, 08:05 AM   #21
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,.... Ya take it Apart, 'n start over...
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
copper or brass? zephed666 Plumbing 17 02-09-2011 09:05 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 08:59 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 10:29 PM
