Old 10-05-2009, 04:51 PM   #1
Question Brand or OEM element in a water heater?
My water heater quit yesterday, and I am assuming it is the element. It is a Maytag "Series 9", dual element, about 8 years old. Lowe's doesn't sell them anymore. Looking on line, to exactly match the 3800 W or the 5500@ (lower element), the element is from $95.00 - $121.00. I went to Lowe's, and they had a "universal" replacement element, 3500W, 4500W,
5500W, each for about $9.00. Could I put this in my hot water heater safely? (Thinking on putting a 3500W element where the 3800W element was on upper, and 5500W on lower element).
Or do I need to get a new water heater? (since it will be 6 weeks for them to order the exact match.)
spentonbargains is offline   Reply With Quote
Old 10-05-2009, 06:57 PM   #2
A "Handy Husband"
As long as the element will physically fit in the heater and is the same or less than the amperage of the standard unit you are aces. No way in the world would I invest $100 in an element for a 8 year old water heater.
rjniles is offline   Reply With Quote
Old 10-05-2009, 07:39 PM   #3
Awesome! Thanks for sharing.....probably saved me $400.
Old 10-05-2009, 08:22 PM   #4
Alot of times if it is a well known brand....the OEM parts usually come from them. For instance, alot of furnace controls or A/C controls, come from Honeywell. You can find a local distributor of Honeywell and can, depending on the Manufacturer of the unit, save anywhere from 5-50%.
Viper16 is offline   Reply With Quote
Old 10-06-2009, 07:01 AM   #5
biggles's Avatar
check out the Grainger Supply nearest you they have all sizes and lenghts www.grainger.com walk right in to buy them
More On This Topic
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
So what you see here is our water heater. And this water heater is a big one, because we want to store as much water as possible when we get the hot water from the sun. If you would use only a 10 gallon or a 20 gallon water heater, and we take a shower... Read More »
IRS Form 3800 is a summary form on which allowable business credits are aggregated before entering the total on your primary tax return. Various business tax credits, such as investment credit, may entitle you to claim them on Form 3800. Since the... Read More »
no water at sink after water heater removal rebelbull Plumbing 1 09-14-2009 09:46 PM
Copper vs. Stainless for Hot Water Heater Element? deeze Plumbing 4 08-19-2009 10:04 AM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 12:57 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
"sticky" gas water heater thermostat homer12 HVAC 7 01-22-2008 08:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
