Brand New Water Heater TPR Valve Spraying - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2013, 12:05 AM   #46
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by TheEplumber View Post
Isn't that in the code book somewhere......
Yep. Problem is, there was ORIGINALLY a tank type water heater there with a thermal expansion tank that was most likely doing the job that a hammer arrestor would. Somebody changed the tank out to a pair of tankless, and shortly thereafter the t&p started leaking.
Let's just say that I came in on the end of all this. Nothing installed by me except the hammer arrestors.
Journeyman Plumber
Old 03-20-2013, 01:58 AM   #47
Always learning...
fetzer85's Avatar
Rewards Points: 262
I was just doing some reading on pressure reducing valves, backflow preventers and the difference between them and came up with a question.
Since our city was pressure is so high (160psi) and I have our PRV set @70psi, is it essentially also serving as a BFP since the TP valve on the water heater should kick open before our water pressure ever gets high enough to flow back into the city's supply?
fetzer85 is offline   Reply With Quote
Old 03-20-2013, 10:08 AM   #48
Doing it myself
Alan's Avatar
Yes. 10char.
Journeyman Plumber
Old 03-20-2013, 10:42 AM   #49
Plumber
TheEplumber's Avatar
Rewards Points: 352
Not when dealing with back siphon.
Old 03-20-2013, 10:26 PM   #50
Doing it myself
Alan's Avatar
Well, technically the T&P valve is acting as the back pressure protection, not the PRV. The PRV is doing nothing in that scenario. If the bypass in the P.R.V. is open, the 70 + PSI that would be built in the system but you could never overcome the city pressure without a properly operating T&P relieving the system.
With all that said, in a real world situation, your municipality is going to ask for a back flow preventer, and more than likely something above and beyond whatever the minimum is.
Heck, the guys here required us to put in a 1-1/4" R.P. device because the store we were plumbing had a pharmacy in it.
WTF is the hazard there? R.P. is for back pressure. There are no pumping devices in a pharmacy. /rant
Journeyman Plumber
Old 03-21-2013, 12:32 AM   #51
Always learning...
fetzer85's Avatar
Rewards Points: 262
I went to Lowes today looking for water hammer arrestors. Unfortunately they only had one kind and it was copper. They were about $11/ea so I pulled my phone out and looked on Amazon to see what they had. I found some CPVC ones for about $8/ea so I ordered 2 of them. I'm not against copper but I favor cementing CPVC pipes together vs. sweating copper...plus its cheaper
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Broken Valve on Water Heater bdr122 Plumbing 11 08-02-2010 11:09 PM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 09:08 PM
