Brand New Moen Posi-Temp Tub & Shower Valve: Model 2300 - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2010, 01:22 PM   #1
Brand new Moen Posi-Temp Tub & Shower Valve: Model 2300
Turn on, works fine.
Turn off, constant drip from tub spout.
Any help appreciated, thanks in advance.
fragonardium is offline   Reply With Quote
Old 04-04-2010, 08:16 PM   #2
DIY staff
Rewards Points: 7,174
You most likely have debris in the valve--This sometimes happens when the old piping is disturbed to install the new fixture.
The valve is new so taking it apart to clean the cartridge should go well.
1. shut off the water to the house --open a few faucets to drain the piping.
2.remove the handle and trims.--Put a towel in the tub first--you don't want to loose any thing down the drain.
3.Remove the horseshoe shaped clip just above the stem.
4.gently pull out the cartridge --a pair of pliers on the stem-pull and twist.the faucet is new-this should do--their is a cartridge pulling tool,but should not be needed if the unit is new-
5.rinse out the cartridge--the little rubber pads pull off--
6.put it all back together.
if it still dribbles--get a new cartridge.--Mike--
Pressure Balance Shower Valve Hammer glenn60 Plumbing 7 06-17-2009 09:30 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
Misbehaving shower mixer valve ranagnos Plumbing 6 03-03-2008 08:24 PM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 08:04 PM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
