Old 09-19-2011, 01:14 PM   #1
Brand new leaking tub spiut
I just bought a new replacement tub spout and 1 part shower delta handle. I've never done this before but I thought I did it right. I wrapped the nipple with tape on both ends and put the new seals on. Now my problem is that my new tub spout leaks when everything is off. It's not a constant leak or drip, but it does drip about 5-7 drops every 10-15 seconds. Maybe I missed a step but I'm not sure. Plumbing isn't my strong point so any advice would be good.
Andruw91 is offline   Reply With Quote
Old 09-19-2011, 04:16 PM   #2
The controls (faucets, valves) are leaking. Could be a loose or bad washer or incorrectly installed cartridge. If not then the spout may drip for a few minutes after the water is turned off but should stop.
Depending on the slope of the pipe coming out into the spout, the last few drips may be several drops at a time then a pause then several more drops at a time, etc.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-19-2011, 04:24 PM   #3
Would it be a good idea to take the trim off and try to reapply it and tightening the valve?
Old 09-19-2011, 05:56 PM   #4
AlbacoreShuffle's Avatar
Most Delta valves have seat springs and washers. If this was a new valve I would take it apart and make sure you didn't get ant debris in the valve while installing it.
Heres a link that may help.
http://www.deltafaucet.com/videogall...eatsandsprings
AlbacoreShuffle is offline   Reply With Quote
Old 09-19-2011, 06:00 PM   #5
Just to clarify I only replaced the trim. Not the valves. It wasn't leaking before I replaced the trim
Old 09-19-2011, 06:05 PM   #6
Same-Same !
Replace the springs and washers and I think you'll be all fixed up.
Old 09-21-2011, 08:14 AM   #7
I replaced the spring and seats and the ball valve. Hopefully that did it. I left a bucket in there overnight to see. Thanks for the help
Old 09-22-2011, 08:58 PM   #8
I fixed the leaking spout, sort of. I fixed the drip by replacing the seats and springs and the valves. Now when I took my first shower in there I found out the when I switch the spout to the shower mode it leaks from the back of the spout in a constant stream of water. It only happens when it's in shower mode not while the water is coming from the spout when it's in tub mode. Thanks for all the help in the first issue and hopefully your advice will help in this matter.
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 12:08 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
