Branch Line Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2008, 12:37 PM   #1
Branch line questions
Our current setup is 1" poly (can't spell it) from the meter to the house then it transitions through galvanized(?) fittings to 1/2 copper through the house, including the water heater. It feeds 10 outlets right now. As you can imagine we can one do one thing at a time. Besides that we're having pressure issues which could be those galvanized(?) fittings. While I have it in pieces I want to upgrade sizes.
From the meter is 25 ft to the house. The furthest run in the house is 40-45 ft including a 20 ft rise to the second floor. I'm going to use CPVC, I'll use thread connections on some of the copper feeds to faucets. The kitchen/2nd bathroom is at the back and the 1st bathroom is in the middle.
Initially I was going to run a 1" about 10 ft from the new brass fittings and use a "T" and branch it off to 3/4 one for the main branch and one 3/4 for the hot water heater. Will that be sufficent or should I at least run 1" till it gets to the back of the house where the kitchen/2nd bedroom will "t" off?
esmith2039 is offline   Reply With Quote
Old 03-21-2008, 01:05 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Bigger is better in this case. When going from CPVC to copper, use the CPVC male adapters with the brass threads.
JDC is offline   Reply With Quote
Old 03-21-2008, 06:41 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Depends on how many fixtures your supplying.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-22-2008, 12:15 PM   #4
So what they say is true What's the difference in using male/female adapters? I used CPVC female adapter/copper male when I setup the laundry room and had a small leak. Had to cut and redo.
2 baths, kitchen, laundry, and outside faucet. Eventually will add a outside kitchen and maybe a dishwasher (big maybe). I guess I need to do some calcuations.
Old 03-22-2008, 09:42 PM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
CPVC female adapters (or any plastic female adapter) can easily crack when a metallic (ie copper) male is tightened into it. Switch it up with a copper female and a CPVC socket X brass male thread adapter and you've reduced that possibility by about 99.7984% or so.
Given that you've got 2 bathrooms (at least 2 lavs, 2 toilets, 2 tub/showers) a kitchen sink and a hosebib, I'd definitely go with 1" if at all possible.
Yes, what "they" say is true. lol
Old 03-22-2008, 09:44 PM   #6
Journeyman Plumber
1" at least till you get beyond or past your 1st bathroom.
Old 03-23-2008, 08:29 AM   #7
I'm guessing your talking about this:
http://www.homedepot.com/webapp/wcs/...3+90129+528105
I don't recall seeing those when I did that laundry room. I really need to find a plumbing store instead of using the big box stores. I should only need 2-4 since the only copper I'm leaving is to the showers.
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Installing drain line parcially upgrade. jbravo8212 Plumbing 8 02-19-2008 06:12 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
