Old 06-01-2009, 06:18 PM   #1
KLR
Default Braided water supply lines - joining two
I need help on the correct way to join two different sized braided water supply lines together, both have the rubber gaskets (One is 1/2" and the other is 3/8" - both female ends). So I need a male/male connector.
The hardware store guy told me this connector would work: 1/2" male pipe on one side and 3/8" compression on the other side. Is this correct? If it is correct then do I use teflon, pipe dope or nothing, on the supply line female to the compression male?
This is going under a jacuzzi tub surround that has no access.
KLR is offline   Reply With Quote
Old 06-01-2009, 08:11 PM   #2
Default He's Right
Yes the hardware guy is right.
No teflon, no dope , don't over tighten, buy good lines.
PS Never install anything you can not get at make an access door somehow somewhere in your surround.
You will be glad you did.
SULTINI is offline   Reply With Quote
Old 06-01-2009, 08:19 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
second that.
Old 06-01-2009, 08:53 PM   #4
KLR
Okay thanks.
My confussion came from reading in several places that pipe threads will not work with compression threads. Then some others that stated to put teflon & dope over all metal threads...
Old 06-01-2009, 09:05 PM   #5
buletbob's Avatar
The end of the fitting will compress against the rubber washer inside the braided hose, its the same as if you connected it to a sink shut off. but a pipe nipple will have a little sharper end to it which could cut into the washer.which would not be a concern to you here, Bob
Old 06-01-2009, 11:04 PM   #6
KLR
Oh, I see now, it is only a problem mixing compression & pipe when using a male pipe end - because the male pipe end is not flat enough & is kind of sharp.
Thanks so much Bob, I will sleep better now. KLR
Old 06-02-2009, 10:10 AM   #7
RippySkippy's Avatar
I wouldn't bury this type of fitting into a space that was not accessible....but that's me. I would rather use flexible copper. Good luck...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-02-2009, 05:05 PM   #8
KLR
Okay, we are now good on the compression end, but what about the pipe threaded male end????...I will be putting a male pipe end into a female compression end that has a rubber washer!!!!
Do I need to find a connector that has male compression threads on both ends????
I only wish I could get to it to change it out to copper. It has access to everything that I am changing out, EXCEPT where the otherside of this flexible connector hooks up to the tub spout.
I am stuck with the flexible connector hooked up to the spout...if the spout ever needs changing...that will be all she wrote for the whole tub and tile surround. For that matter if the flexible connector goes bad... ...oh man I can't just abandon the spout...it would look rediculous.
What should I do? helppp?
Old 06-02-2009, 05:53 PM   #9
Go back and read post #2 and follow it, don't complicate the job any more than it is already. Not directing just advising.
Tags
teflon water supply line
More On This Topic
Hi this is Fernando we are here with Expert Village and now we are going to go over to how to connect your pvc piping. One of the things that is very important to do is make sure all of your surfaces are clean. Some people like to use sandpaper to give... Read More »
Now that I have my slab prepared you need to get a drywall knife or some other very thin, very smooth and flat implement that you can use to compress and smooth the clay. And you're just going to go over it a couple of times. From a couple of different... Read More »
Shaping a Clay Pitcher
Shaping a Clay Pitcher by Expert Village
There's another way to make a pitcher with a spout, and this way we're going to actually cut a piece of the pot away and leave a spout there. I've already done the steps that I did previously, and I've got it up into a cylinder. Now we need a different... Read More »
Making a Clay Steamer Spout
Making a Clay Steamer Spout by Expert Village
So now we're ready to make the interior spout. And the way we're going to do that is we're going to pinch near the bottom, compress with the right hand and the sponge. Have just enough moisture that if you need to squeeze it, you can get a little bit out... Read More »
Pull Steamer Walls
Pull Steamer Walls by Expert Village
Now we're ready to pull the wall out. Get it wet, pinch with your left hand, take your right thumb, make yourself a little undercut so that you've got a place to start pulling. You pinch under that undercut, compress with the right hand, pull with the... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 05:01 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 07:18 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 06:23 PM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 03:22 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
