Bradford White Water Heater (50 Gal) Not Working - Might Be Blower? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2009, 01:36 PM   #1
Wink
Bradford White Water Heater (50 gal) not working - might be blower?
10+ yr old Bradford White water heater stopped working. 1 plumber said the blower/motor is broken. Current blower motor is Jackel #117524-00 and 1150519-00. Getting all sorts of advice as I assess who should fix this - does it require an HVAC specialist? can a general plumber fit it? Parts also seem hard to locate - one plumber estimating 10 days! Does machine require a Jackel product. And finally, most importantly, what's a good price on the parts. Thanks if anyone can weigh in with advice.
Lesdeak is offline   Reply With Quote
Old 07-18-2009, 09:49 PM   #2
HVAC / Plumbing
At that age .. I probably wouldn't put alot of $ into it
kenmac is offline   Reply With Quote
Old 07-25-2009, 02:51 PM   #3
Same blower, but it's slow not dead
I have exactly the same blower motor on a 15-yr-old Bradword White 30 gallon water heater. It hasn't died yet, but over the past two weeks the motor has become very slow to start up. It hums and strains and turns lazily and then finally kicks in at full speed. What would cause this? (And to the person who started this thread, did yours do that before conking out?)
GailL is offline   Reply With Quote
Tags
bradford white , inducer , jackel , water heater
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Water Heater Troubles deadguydrew Plumbing 9 10-19-2008 09:30 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 01:51 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
