Bradford White Sacrificial Anode Replacement Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2009, 04:40 PM   #1
Bradford White sacrificial anode replacement problem
I have a 75 gallon Bradford White hot water heater. I went to replace the sacraficial anode today, it is also the outet for the hot water. I unscrewed it all the way, but I could not get it to come out. I tried prying it, and tapping with a hammer, but it still wouldn't go. Any suggestions?
vinnie1 is offline   Reply With Quote
Old 07-26-2009, 08:24 AM   #2
Rewards Points: 1,538
It may have become coated with lime to the point where it is now too fat to come out through the hole.
You could, not too forcefully, pump it up and down to try to scrape off the sediment as it comes out, although you do not want to deform the hole that has to accept the screw thread of the new rod.
I'm not sure of any adverse consequences but I would cut it off and let it fall to the bottom of the tank and then install the new rod.
Incidentally, the rod covered with lime is no longer able to perform its sacrificial duty although most likely the tank insides are also covered with lime which according to some books on plumbing offers additional protection against rust.
In the future, inspect the rod more frequently and also scrape it clean, down to the bare metal, if needed before re-inserting it.
Old 07-26-2009, 08:53 AM   #3
Water quality'n pump guy
If the rod is being removed because of odor problems, scraping any of the rod material off into the tank is like not removing the rod.
The bacteria living in the water heater make the rod 'swell', it is not lime/hard water scale or you would not be able to scrape it off the rod.
Gary Slusser is offline   Reply With Quote
Old 07-27-2009, 08:01 PM   #4
I have never known rods to get bigger. They are sacrificial and actually get thinner. You didn't describe the thickness, just that it would no come out.
Andy Christensen, CWS-II
Andy CWS is offline   Reply With Quote
White Laminate Cabinets Problem Shamrock Painting 5 05-01-2011 07:59 AM
sill angle problem replacement window drewhart Building & Construction 1 10-30-2008 09:56 PM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 08:24 AM
problem in wiring white LED beawer2323 Electrical 4 12-06-2007 10:19 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
