-   -   Box around a shower drain in concrete, what do I do with it? (http://www.diychatroom.com/f7/box-around-shower-drain-concrete-what-do-i-do-68814/)
rick42wood 04-11-2010 02:00 PM
I am installing a new shower pan on a concrete floor. When I had the floor poured to fill in the places I had to jackhammer to move the plumbing around I was advised to put a 6"x6" hole in the concrete around the pipe that is for the shower drain. I am ready to install the shower base now. My question is, what do I do with the "box" around the drain pipe? Should I fill it with sand, insulation, or leave it empty?
majakdragon 04-11-2010 02:22 PM
Your choice as long as it isn't in your way. I would use the insulation idea.
rick42wood 04-11-2010 02:58 PM
Anther question, Shower drain
Thanks for your reply, I,ll stuff it with insulation.
Would the drain fitting normally be attached to the shower pan first and then dropped onto the pipe? The pan instructions suggest spraying expanding foam insulation under the pan and then filling it with water after leveling. This is a lot to get done before the expanding foam sets up. Any suggestions?
Scuba_Dave 04-11-2010 06:21 PM
Fiberglass will hold any water/humidity/condensation
I'd use something else
rick42wood 04-11-2010 07:24 PM
Good point, I'll stuff it with styrofoam packing.
majakdragon 04-11-2010 10:28 PM
I am guessing the pan is plastic or fiberglass and the spray foam is serving as a mortarbed. I prefer premixed mortar from a bucket. The foam can depress and will not go back up when/if the pan moves up and down. This can allow for cracking later. There are a few different types of drain connectors including the one you slip over the pipe after the pan is set.
