Old 12-28-2012, 03:39 AM   #1
747
registered
747's Avatar
Bought new toilet
American Standard Champion 4. 1.6 gallon flush. Had it about 2 weeks now. Very happy. Powerful-flush. Highly recommend. Elongated bowel ever clean and Ada compliant. Got it a Lowe's
Thinking about new toilet grab this one.
747 is offline   Reply With Quote
Old 12-29-2012, 05:30 PM   #2
Bought new toilet
I heard the champion 3 is the one to have, but glad your happy with it.
paintdrying is offline   Reply With Quote
Old 12-29-2012, 06:44 PM   #3
Master Plumber
Javiles's Avatar
Bought new toilet
Now all you need are the accessories
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 12-29-2012, 07:03 PM   #4
Bought new toilet
Where’s the beer and T.V?
epson is offline   Reply With Quote
Old 12-29-2012, 07:25 PM   #5
Bought new toilet
Any links? I'm not familiar with this model.
Do you mean the Cadet 3?
stephen9666 is offline   Reply With Quote
Old 12-29-2012, 08:00 PM   #6
Bought new toilet
read up on this: http://www.democraticunderground.com...ss=105x3096101
Old 12-29-2012, 08:18 PM   #7
Roofmaster
Bought new toilet
I bought a new AS toilet about 33 years ago and installed it for my aunt. I had to repair the floor and the closet bend, then carefully installed the toilet, something I had done many times before and many times since. After about a week the gasket between the tank and the bowl started to leak soaking the floor again. I have never purchased another AS Product since, and I see from the previous post why. Too Bad, American Standard used to mean something.
By the way how is the clog proof toilet supposed to work when the paper floats? Wont it just float over and clog the overflow drain holes?
I use Kohler and have always had good luck with the Wellworth Classic
" A lot of men build things, and a lot of things fall down "
jagans is online now   Reply With Quote
Old 02-14-2013, 05:39 PM   #8
Bought new toilet
I too recently installed a Champion 4. Some observations and issues: the flush handle mechanism is cheap plastic and can barely lift that huge 4 inch flush valve. I replaced it after a week with a nice universal all metal one. The toilet seat is junk. Replaced it as well. The huge 4 inch flush valve is an issue all to itself. When you flush, the float/flapper pulls off the seat and lots of water gushes down past the float and into the bowl. Well, so much water gushes past the float all at once, it immediately slams the float back down onto the seat. Only about half the water in the tank is emptied. I’ve played with the chain length and it makes no difference. It’s almost as if it is designed that way. Flush and release for a light flush, flush and hold for a complete flush. Even a flush and release does seems to empty the bowl, but why only emptying half the water in the tank? Overall it seems to work OK, but my 10 year old Kohler’s work good too and have never had a problem with them.
rustyedge is offline   Reply With Quote
Old 02-15-2013, 11:44 AM   #9
Bought new toilet
Originally Posted by rustyedge View Post
It’s almost as if it is designed that way.... Even a flush and release does seems to empty the bowl, but why only emptying half the water in the tank?
It probably is designed that way. Some modern toilets don't empty the entire tank on each flush by design. Unless you want a toilet with a tiny tank, then 1.28 or 1.6 toilets may not empty the entire tank.
One benefit is that the cold incoming water mixes with the room-temp water that's sitting in the tank, so tank sweating is less common.
My Drake II doesn't empty the tank on every flush. If you hold down the handle to empty the tank, you're using more water than the 1.28 gallons it's supposed to use. I don't think my Mansfield Cascade empties the entire tank, either.
The Following User Says Thank You to stephen9666 For This Useful Post:
rustyedge (02-15-2013)
Old 02-15-2013, 12:11 PM   #10
call me E
TheEplumber's Avatar
Bought new toilet
My Drake II doesn't empty the tank on every flush. If you hold down the handle to empty the tank, you're using much more water than the 1.28 gallons it's supposed to use. I don't think my Mansfield Cascade empties the entire tank, either.
I recently installed 2 similar toilets in an old church. The lines are very old galvanized and are quite restricted.
The problem was the tank took too long to refill between flushes On sunday morning after a service- that's not good. The 1.28 "half flush" solved the problem. It was still a powerful enough flush to give the bowl a good wash out
Old 02-15-2013, 04:25 PM   #11
747
registered
747's Avatar
Bought new toilet
Zero problems so far. Haven't used the plunger. My other bathroom has the old school crane flush toilet. Its in such great condition i haven't changed it.I think its 3 gallon if not more flush. I had to replace flapper. Order it off amazon couldn't find one anywhere. Crane toilet flappers are had to find. Its the one which has the slit in the back.
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 02:39 PM
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 11:02 AM
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 12:12 PM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 05:01 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
